Discussion topic: Upgrade to SkyQ
Message posted on 30 Jan 2024 09:00 PM
Upgrade to SkyQ
I have an Ultra HD box and when a Sky engineer visited recently to check my connections (due to problems when the wind blows), he suggested I should upgrade to SkyQ. I can't find anywhere on my Sky App or the website which helps me to contact someone to assess this possibility. Is there a real human I could speak to, please?
Message posted on 30 Jan 2024 09:04 PM - last edited: 30 Jan 2024 09:05 PM
Re: Upgrade to SkyQ
hi @Fozzie60
Do you mean you have a SKY HD box ? as SKY Ultra HD boxes are SKY Q
Message posted on 30 Jan 2024 09:59 PM
Re: Upgrade to SkyQ
It has "Sky+HD" printed on it and is one of the bigger older ones.
Message posted on 30 Jan 2024 10:02 PM
Re: Upgrade to SkyQ
hi @Fozzie60
In which case if you want to upgrade to SKY Q then you will need to call - if you have received a letter there should be a number on that.
Otherwise, if you have the MY SKY app I think you may be able to find a number there - especially if you are a SKY VIP member
If not go this page & scroll to the bottom and expand the link need more help & scroll down
https://www.sky.com/help/home
If you have SKY Mobile or SKY Talk land line then I think you can also call 150
I would, however, suggest you read some notes I have made for people considering switching from SKY +/HD to SKY Q
Message posted on 30 Jan 2024 10:04 PM - last edited: 30 Jan 2024 10:05 PM
Re: Upgrade to SkyQ
@Fozzie60 wrote:It has "Sky+HD" printed on it and is one of the bigger older ones.
That's not Ultra HD, that's jist HD.
There's a good write up by nigea on here about what to consider when upgrading because it's a quite different experience. A lot is better, a few features are missing, a few navigation things are a bit bizarre.
(and as if by magic, he posted it while I was writing that)
Message posted on 30 Jan 2024 11:15 PM
Re: Upgrade to SkyQ
I'm wondering if the opening line was meant to say "I have an Ultra HD TV"
If so, there would be an extra UHD subscription needed to make most use of it with Sky Q.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
