Discussion topic: Hi i problem with sky q
Message posted on 30 Jan 2024 09:52 PM
Hi I got problem with sky q box I took the main power off for ten minutes and then is only power turn on but is not goes I home and app and move the channels
Message posted on 30 Jan 2024 10:05 PM
Re: Hi i problem with sky q
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
