Discussion topic: Upgrade my subscription to view and Missing Apps
This message was authored by: Tinman76
I've just received a new Sky Q box after first was sent back due to having missing apps. After setting up this box I'm still having the same issues. I've done everything the community suggests I should to resolve this issues. I also getting a message saying that I to upgrade my subscription to view but I have all the subscription to view such channels like Netflix, Paramount plus, Discovery Plus and other such channels. Please Help!
Re: Upgrade my subscription to view and Missing Apps
Is your box connected to your internet? Is it through WiFi or a cable?
Avatar for Tinman76
Internet all set up via a Wi-Fi connection.
Try the following and refresh all apps:-
https://helpforum.sky.com/t5/Sky-TV/Sky-Q-hidden-menu/ba-p/4364881
Avatar for Tinman76
I've already done all these and it's still the same!
@Tinman76 not sure if you are aware but it can take upto 24 hours for the app refresh to work usually less but can be upto 24 hours
also what firmware/software version is your box on
Avatar for Tinman76
Seem the box is up to date! Q230.000.14.00L.
