Discussion topic: Upgrade but already subsctibe
This message was authored by: Grahampb
We subscribe to Sky and are suddenly getting a message to upgrade the account in order to access channels. But we have the subscriptions and it's been working  fine for year and we've been viewing and recording until this past week.
Any help would be appreciated
Re: Upgrade but already subsctibe
@Grahampb
Are you trying to view content in HD or UHD without the required add-ons?
Avatar for Grahampb
Level 2 icon
No,  everything is paid for. It was writing this morning and now it has suddenly stopped. Tried all the troubleshooting guides but no luck. I can view it on the app but not on the TV.
Avatar for Grahampb
Level 2 icon
It is odd because I van watch it online or on the app but not on the TV?
hi @Grahampb
The first thing, I suggest, is to power down restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
If that doesn't cure it then try re-freshing the viewing card :
Main Menu -> Settings -> System Info  scroll across to the viewing card & click on 'setup'
Then click on the button (the whole message) which ends 'Use this option to trigger a callback'
This isn't a call back as such but initiates a refresh of the viewing card - Note this  could take a few minute, or many hours or even a day or so
May I ask what programme & channel  you are having problems with ?
Avatar for Grahampb
Level 2 icon
It was sky sports main event
Avatar for Grahampb
Level 2 icon
Still no luck
Can you view any of the other Sky Sports channels?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Avatar for Grahampb
Level 2 icon
Yes, and all of them on the app.
@Grahampb I know you say you have all the subscriptions do you have the UHD subscription ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Grahampb
Level 2 icon
Yes, UHD, HD, Cmplete Sky Sports
