1
This discussion topic has been answered Discussion topic: Update Sky Q
This message was authored by: tracyp
Update Sky Q
Since my Sky Q got an update, I am having issues with watching recordings via Sky Atlantic,Sky Witness and ID channels, I get to watch the programme up to the first advert then it freezes, so I have to unplug and restart the box again, it does it again and its so annoying. Any help please.
Re: Update Sky Q
Hi @tracyp
Re: Update Sky Q
Hi @tracyp
