Discussion topic: Unsuccessful login message repeatedly
Message posted on 23 Apr 2026 10:52 PM
Message posted on 24 Apr 2026 07:17 AM
Re: Unsuccessful login message repeatedly
@LAAllen wrote:
I am entering the correct network password but the sky box isnt accepting it. Other devices are linking so I know its correct,could it be a sky box issue?
Is this a Sky Q box you're trying to connect? Who supplies your broadband and are you selecting the Sky router or 3rd party router option? Are possibly inputting a 0 instead of a O or 1 instead of a l for instance?
You're usually given the option of using the wps button on the router to connect to a Sky Q box at least, be aware the Q box being old can be slow to respond to the various steps and make you think it's frozen, treat it as a little old man who doesn't move quickly and be patient.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
