Discussion topic: Unsuccessful connection to internet
This message was authored by Ryan60 This message was authored by: Ryan60
I cannot gain access to the internet on my Sky TV. I've reset it and inputted my password however it states unsuccessful connection.
My wi-fi is working with all other devices in the household.
Re: Unsuccessful connection to internet
Hi @Ryan60
