8
This discussion topic has been answered Discussion topic: Unknown Router
This message was authored by: JohnLey
Unknown Router
Sky q tv connecting to unknown router
This message was authored by: MightyQuinn Answer
Re: Unknown Router
@JohnLey wrote:
Thank you as you say very confusing
I tried the sky phone help line but just went round in circles trying to find the right person to help
Hi @JohnLey   It is a virtual SSID generated by the box, especially if it starts with Skyxxxx. You can safely ignore what it displays. As an example mine used to show a BT router name that I got rid of years ago. If it works, then everything is fine.
Re: Unknown Router
What makes you think this?
by the way your post was phrased like you were maybe expecting a bot response. This forum is a customer-customer area.
Re: Unknown Router
hi @JohnLey
if this is a SKY network then this is likely to be showing the SKY Q's own wifi that it generates for connecting to minis
Avatar for JohnLey
Re: Unknown Router
In my sky q settings the network name is different to the one on my router.
My phone is showing the correct name.
I have tried resetting it but it continues to find the other network
Avatar for JohnLey
Re: Unknown Router
I don't have any sky mini boxes
Re: Unknown Router
hi @JohnLey
The SKY Q box main still generates a wifi & this is often listed as the network, which we know is confusing
Avatar for JohnLey
Re: Unknown Router
Re: Unknown Router
It should also be noted all wifi signals are password protected, a Sky Q box or any other device for that matter cannot just link itself to a different wifi network without  a password.
As mentioned the other SSID will likely be generated from the Sky Q box itself, if your Sky Q box is working correctly then there is no point calling Sky as there are no issues with it.
Re: Unknown Router
