Discussion topic: Unable to record some programmes on SkyQ
This message was authored by: BC73
When I try & record a programme in SkyQ I can't, just get the message'this programme cannot be recorded' has happened a few times in the last few days with ITV, Channel 4 & Sky channels.
Re: Unable to record some programmes on SkyQ
Hi @BC73
This message was authored by: G14LYR
My main problem is with Channel 5HD.  Thanks for the advice, unfortunately, it did not work for me.  Any other suggestions?
Do you have HD pack?  Can you watch the channel live?
