Discussion topic: Unable to purchase smith vs eubank fight
Message posted on 02 Sep 2023 06:06 PM
When I press to select the event I get a message which says 'to purchase this event contact the event broadcaster' I've purchased boxing before without any issues - any help will be much appreciated!
Message posted on 02 Sep 2023 06:14 PM
Re: Unable to purchase smith vs eubank fight
@Soozjones Best to call Sky.
You can call on 150 from a Sky Talk Line or Sky Mobile.
(UK) https://www.sky.com/help/home Scroll down and click on ‘Need more help’ and it provides a 0333 number
(ROI) on the same link change the flag in the very bottom corner to the ROI flag to obtain an 0818 number.
Stay on the line and don’t hang up if prompted to. Apparently the quieter times to ring are just after 7am or about 9pm.
Message posted on 02 Sep 2023 06:15 PM
Unable to use my Sky Q remote to order PPV events
Sky Q remote does not work when trying to order PPV events, Sky cannot fix the problem.
Message posted on 02 Sep 2023 06:16 PM
Ordering sky box office
Trying to order boxing on sky box offices
Message posted on 02 Sep 2023 06:17 PM
Re: Unable to use my Sky Q remote to order PPV events
If you've already spoken to Sky then I'm not sure what fellow customers can do either.
How do you know? Have you reported it to them already?
Message posted on 02 Sep 2023 06:29 PM
I reported this issue last year Sky did not fix it then and still cannot fix it.
Message posted on 02 Sep 2023 06:32 PM
So basically you don't know it's the same issue.
(By the way, because of the tag name you've chosen we can't tag you in our replies)
Message posted on 02 Sep 2023 06:34 PM
It is the same issue, I want to buy the PPV event to record it, but I am still not able to do so and Sky cannot solve the problem
Message posted on 02 Sep 2023 06:36 PM
Then as post 2 above by @GD1 give Sky another call and report it again. As customers like you we can't fix it for you.
Message posted on 02 Sep 2023 06:45 PM
@Daniel0210 Yes I reported the problem last year and again yesterday. Problem not fixed.
Message posted on 02 Sep 2023 07:45 PM
Had them same issue.
Fixed for me as its just let me purchase this.😁
Message posted on 02 Sep 2023 07:47 PM
@atn1963 Mine fixed as well ✅✅
