Discussion topic: Unable to get sky or catchup demand
This message was authored by: Jayne69
Changed to sky signature still using q box but now unable to connect to sky catchup and demand
On home says no Internet but WiFi  broadband ok
This message was authored by: Addie15
Re: Unable to get sky or catchup demand
This message was authored by: Mr+Flibbles+86
We are still looking to help you @Jayne69 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Hi @Jayne69
If you still have issues,
