Discussion topic: Unable to get my Netflix through sky
Message posted on 23 Apr 2024 10:33 PM
I was on my son's Netflix it is now unlinked and I still can't get mine on the tv??
Message posted on 23 Apr 2024 11:48 PM
Re: Unable to get my Netflix through sky
Do you subscribe to the "Ultimate TV Pack"
as this is the package required for Netflix. It's the new base package but if your still on the legacy bundle then Ultimate TV won't be included
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 24 Apr 2024 06:22 AM - last edited: 24 Apr 2024 06:23 AM
On the TV or on your Sky Q box?
If the latter, what happens when you try?
Message posted on 24 Apr 2024 09:32 AM
@Pegpeg wrote:I was on my son's Netflix it is now unlinked and I still can't get mine on the tv??
It sounds like you’re having trouble linking your Netflix account to your TV.
Here’s a step-by-step guide to help you get connected:
Ensure Your TV is Compatible: Make sure your TV has the Netflix app available. Most smart TVs come with the Netflix app pre-installed or available in their app store.
Connect to Wi-Fi: Your TV needs to be connected to the internet to access Netflix.
Open the Netflix App: Navigate to the Netflix app on your TV. If it’s not on the main menu or home screen, you may need to search for it in the app store.
Sign In: Once you open the Netflix app, select ‘Sign In’ and enter your Netflix account details. If you’ve previously signed in with a different account, you might need to sign out first.
Troubleshooting: If you’re unable to find the Netflix app, your TV might need a system update. Check your TV’s manual or contact the manufacturer for instructions on how to update your TV.
Using a Mobile Device: If your TV supports casting, you can use your mobile device to cast Netflix to your TV. Open the Netflix app on your mobile device, sign in, and look for the cast icon to connect to your TV.
Alternative Methods: If your TV doesn’t support the Netflix app, you can use a streaming media player, game console, or connect your computer to the TV using an HDMI cable.
DogNearMe
