Discussion topic: “No satellite connection” suddenly appeared. Have been watching via broadband for years. Today could
This message was authored by: Dunfermlinebiy
Have connected via broadband for years... satellite cable not used. Today no tv guide available. Says "no satellite signal" Don't understand why this has happened. All apps/recordings etc ok
Re: “No satellite connection” suddenly appeared. Have been watching via broadband for years. Today c
@Dunfermlinebiy  Sky stream doesn't use satellite so it can't be a message with a Stream box.
It's likely a TV message if it has an inbuilt satellite tuner.
Do you actually have any Sky TV equipment at all?
Avatar for Dunfermlinebiy
Yes, I have sky q.... 3 boxes all with same issue. I've done nothing different yesterday. Haven't used the connection from disk for years. Can still get bbc live via iplayer but list of channels not appearing
@Dunfermlinebiy  As it's a Sky Q issue your post has been moved.
Please try the steps here https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-live-tv/no-satellite-signal/articl...
You need a satellite connection to use Q.  Are you saying it's unplugged from the dish?
I haven't needed a dish connection for about 5 years
@Dunfermlinebiy
Then you wouldn't have Sky Q.
@Dunfermlinebiy
...or it definitely is Q with miniboxes then I'm surprised it's worked for so long as they usually stop after a few weeks without Satellite 'keep alive' signals.
If so, the *only* fix is to reconnect the dish.
This message was authored by: Invisiblename
Sorry, but Iv'e got to ask: is this a wind up?  Sky Q is a satellite based system, always has been.  The satellite feed needs to be connected to the main Sky Q receiver at all times, because Sky randomly sends a verification to your box via the satellite; if it doesn't get a response (via the internet), it stops your box working (and any connected Sky mini boxes) - even previously recorded programmes.
Oh, and all Live trasmissions are transmitted via the satellite.
I just don't understand how it can have working for 5 years with no satellite feed.
I am just another Sky customer!
@Dunfermlinebiy  Perhaps a photo of the box can help clear this up.
@Dunfermlinebiy are you talking about one of your mini boxes as the main Q box needs connecting to the dish but the mini boxes connect via wifi or ethernet cable to your main box.
If its the mini box Have you tried rebooting your main Q box ie
then
rebooting the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
The main Q box absolutely requires a satellite dish connection cable and signal.  Its associated Mini boxes don't themselves have their own direct dish feeds because 'their' satellite tuners are in the main Q box, and it's that box which rebroadcasts the received and decoded live television channel data to them.
