3
This discussion topic has been answered Discussion topic: Unable to get TV signal on other tvs
This message was authored by: ClaireClaire40
Since installing skyQ in the living room the other TV's in the bedroom can't get a TV signal. The two aerial cables that were previously in the Sky+ box have been joined together but still no signal in the other tvs
This message was authored by: PandJ2020 Answer
Re: Unable to get TV signal on other tvs
Joining the cables should work.  If it doesn't then you may need an amplifier (the Sky+ box would have provided this).
Sky won't be interested in any issues with terrestrial reception.
hi @ClaireClaire40
I would also check that there is another loose cable - if this is the case then you may have to play with different combinations to see which works & as @PandJ2020 you may need an aerial ampliefier to give 2 outputs
Avatar for ClaireClaire40
Thanks @nigea99  & @PandJ2020 amplifier worked a treat.
