Discussion topic: Unable to connect s
Message posted on 13 Jan 2024 11:24 AM
Unable to connect s
Unable to connect sky q box to internet
Message posted on 13 Jan 2024 11:32 AM
Re: Unable to connect s
Hi @Julia26
Assume this is your main Q box?
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Message posted on 13 Jan 2024 11:33 AM
Hi @Julia26 Try following the guide Setting up Sky Q - Sky Q box - Selection | Sky Help | Sky.com
