2
This discussion topic has been answered Discussion topic: Sky Q mini box tv showing No signal
This message was authored by: Juanita47
My SkyQ mini box has green light  but when I switch tv on sky comes up on screen but then goes to no signal.  The main tv and box are fine.
This seems to have happened after I was watching dvd on main tv although this might not be relevant.
Do I really have to go through re-boot of  main tv?
Re: Sky Q mini box tv showing No signal
Hi @Juanita47
Yes, First try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Hi @Juanita47
Avatar for Juanita47
Thank you for replying. I really didn't want to go through this whole process again. I had to do it last month when both boxes lost signal.
It is driving me nuts and I wish I had never switched to skyq
