Discussion topic: Unable to connect TV
This message was authored by: Flippityjib
I have been unable to connect my sky boxes to internet so cannot watch TV for last 3 days
Re: Unable to connect TV
Hi @Flippityjib
Start with the main Qbox.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
@Flippityjib  Not being able to connect to the internet would not stop Sky Q boxes from receiving satellite channels, do you have Sky Q or Sky Stream?
