Discussion topic: No internet connection
Message posted on 16 Nov 2023 06:16 PM
Hi, a message is coming up advising we have no internet connection. The tv is still working however the tv in the bedroom which is connected to a mini box is not working
Message posted on 16 Nov 2023 06:22 PM
Re: No internet connection
Hi @Maria30
Reboot the mini as above.
