Discussion topic: Unable to activate Discovery Plus
Message posted on 04 Jul 2026 02:43 AM
When the sky engineer came to install the new Sky Q box he asked if there was anything I wanted. So I said I would like Discovery Plus. How ever he used an incorrect email address. Is there any way I can correct this so I can use it?
Message posted on 04 Jul 2026 02:10 PM
Re: Unable to activate Discovery Plus
@rosemary+norwich wrote:When the sky engineer came to install the new Sky Q box he asked if there was anything I wanted. So I said I would like Discovery Plus. How ever he used an incorrect email address. Is there any way I can correct this so I can use it?
I think the approach depends on what you can and can't do now.
For example, if you can log into your Discovery+ account online with the wrong email address, you can still update it in the account to the correct one.
But I suspect that your Sky account and Discovery+ are linked by this incorrect email address and changing one isn't enough. You will need to ask Sky to unlink your account so you can re-activate it with the correct address.
You can get help from Sky here: https://www.sky.com/help/articles/discovery-plus-homepage
There is some stuff here about changing an email address via Discovery+: https://support.discoveryplus.com/ie-en/Answer/Detail/000004054
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
