8
This discussion topic has been answered Discussion topic: No satelite signal on mini box
This message was authored by: LindaPatt
The main Sky Q box is working fine although I had to reset it earlier because it wouldn't switch on from standby & the tv attached to the mini box said no signal. The mini box still shows no satelite signal even though I've followed all the troubleshooting procedures. The main box shows the mini box is attached & ready to use. Any ideas would be appreciated
Re: No satelite signal on mini box
Hi @LindaPatt
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Hi @LindaPatt
@LindaPatt  Did you power down both the main Q box & mini box, then power up the main box allowing to fully reboot before doing the same with the mini?
If you didn't wait for the main box to fully reboot you'll need to try the steps again.
Avatar for LindaPatt
@GD1 yes I've done all that but I'll try it again. I did the reactivate on the main box for the mini box aswell. Like I said I'll try again & report back
@GD1 @It's just come up with an error on the main box that there's an issue with the hard disk drive & to try restarting the box. Does that mean switching off at the wall again?
@LindaPatt  This link will help with the error https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
@GD1 yes I've just found that. I daren't do it just yet as the football is on & I won't be popular with the other half if it doesn't work! 😂
@GD1 I've done the reset & it appears to have worked. Thanks
This message was authored by: rjb2910
Now got sky home page with guide at side but can use either frozen can't use remote no response
