Discussion topic: Ultra hd
This message was authored by: Jamie54
Ultra hd
I've signed up for ultra hd but it's not working, I have a ultra hd t.v and I've been on the settings and gone to picture to change resolution, the highest resolution is 1080p.
Re: Ultra hd
Hi @Jamie54
See following help link
https://www.sky.com/help/articles/setting-up-ultra-hd
This message was authored by: Jones_The_Cat
Re: Ultra hd
It's possible that you have an older non-UHD Sky Q box. If this is the case then you'll need to ring Sky and request a new updated box. There will probably be a charge for this and you will lose all recordings on your current box.
Re: Ultra hd
@Jamie54 from the link @oldfella posted i'd check the part in regards to what Q box you have
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
