Discussion topic: Ultra HD
Message posted on 23 Dec 2024 12:59 PM
Ultra HD
Message posted on 23 Dec 2024 01:02 PM
Re: Ultra HD
Have you already got HD? You need that add-on first.
Message posted on 23 Dec 2024 01:04 PM
Re: Ultra HD
@Mbc1310 wrote:
I have sky q and UHD TV but I can't upgrade to UHD anyone know why
do you have a UHD capable box ?
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
https://www.sky.com/help/articles/check-which-sky-q-box
