This discussion topic has been answered Discussion topic: Uhd set up
Message posted on 20 Nov 2024 11:21 PM
Message posted on 21 Nov 2024 09:13 AM
@Mistymoomoo wrote:
Thanks I have 32 cooA
hi @Mistymoomoo
In which case if you want UHD you will need to call SKY to upgarde th ebox which currently seems to cost around £99 - although I guess there is a chance you may be able to negotiate.
To watch SKy content in UHD you will also need the UHD add on
Make sure that if you do upgrade you specify that you want an HDR capable box
BTW when sapping your box make sure you take your viewing card out of the old box to be able to place it in the new one
Message posted on 21 Nov 2024 08:02 AM
Re: Uhd set up
Do you have a UHD subscription?
What hardware version is your Q box?
Message posted on 21 Nov 2024 08:09 AM
Re: Uhd set up
hi @Mistymoomoo
Girts thing is tp check which box you have
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
Message posted on 21 Nov 2024 09:08 AM
Re: Uhd set up
Message posted on 21 Nov 2024 09:10 AM
Re: Uhd set up
@Mistymoomoo wrote:Thanks I have 32 cooA
Then you have a non-UHD box.
If you want to upgrade then you'll need to call Sky - they'll charge around £50-100 to swap for a newer one. But not worth it unless you have a UHD sub too...
hi @Mistymoomoo
Message posted on 21 Nov 2024 09:55 AM
Re: Uhd set up
Thanks for that do you know if i will I be able to keep my films I bought from sky store if I keep my card ?
Message posted on 21 Nov 2024 09:59 AM
Re: Uhd set up
@Mistymoomoo wrote:Thanks for that do you know if i will I be able to keep my films I bought from sky store if I keep my card ?
Yes, you can redownload them.
Message posted on 21 Nov 2024 10:01 AM
Re: Uhd set up
Hi @Mistymoomoo
Any content you have bought from SKY Store can be download to the upgrade box
