Discussion topic: Uhd my backside
This message was authored by: Leds1
Uhd my backside
401 is supposed to be uhd but it's exactly the same as the hd channel, it's a conn again from sky. Yes my settings are on uhd !!
Re: Uhd my backside
Some material is upscaled from HD.  It depends on the available feed.
Re: Uhd my backside
Can I ask what is the model and size of your TV @Leds1 ?
This message was authored by: bob1234
Re: Uhd my backside
@Leds1Can you watch anything downloaded in UHD. The "Gangs of Lemur Island" used to be a good test, if it is still available in UHD.
Re: Uhd my backside
"con" as in "confidence trick" not "connection" 😉
What were you watching?
This message was authored by: best+of+the+best
Re: Uhd my backside
@Leds1 401 SkySpME UHD so what Channel is SkySpME HD 858
Showing 401 UHD for me with HLG HDR  BT.2020 not a conn then maybe a faulty box
Re: Uhd my backside
"con"
This message was authored by: Ecosse
Re: Uhd my backside
My check is the difference seen on F1 UHD as opposed to the HD F1 offering, it's chalk and cheese.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
