Discussion topic: UHD setup not working UH031 error
25 Aug 2023 02:37 PM
Hi,
I have a Labgear HDXS450K 4 way HDMI splitter that is capable and setup for 4K @ 60Hz within the EDID management setup.
I use this on my Sky Q box.
However, I have noticed the screen resolution is a little bit blurry on my new Samsung 65 inch TV that is 8K capable.
I have attempted to setup the Sky Q box to 2160p resolution and it's giving me the EH031 saying the setup for UHD has not worked. It gets to the stage of asking if I want 10-bit, 8-bit or Find For Me. I've tried all options with the same result.
The screen went blank and then for a split second I could see a little box in the middle of the screen with the countdown but then it comes up with the error message and goes back to the 1080p.
I'm not sure what to do now. The splitter is doing its job fine so I know it's not that now.
Could it be a setting on the Samsung TV?
PS. I don't have the UHD subscription but do have HD upgrade on. I just want to set it up as I know the picture quality on BBC1 HD, BBC2 HD, ITV HD, C4 HD are not as they should be really. Something isn't right.
