7
This discussion topic has been answered Discussion topic: UHD has disapeared from box
This message was authored by: TonyGW
I have an active UHD subscription which has worked on my box for years.  Now it has disappeared and all my channels show as HD only.  Also i no longer download UHD.   My account shows UHD subscription is active,
Re: UHD has disapeared from box
@TonyGW wrote:
😃 yep. tried that too!
Im thinking I need to call them up.
Hi @TonyGW
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Hi @TonyGW
Make sure that your Q box is still set to 2160p resolution.  10 bit if HDR compatible.
Avatar for TonyGW
thanks.  have checked that.  and it is correctly set to UHD.
When I try to download UHD, it says "no subscription".   but if i try to add a UHD subscription it correctly says already subscribed.
Strange !
Hi @TonyGW   Have you tried a power reboot?
Avatar for TonyGW
Hi @TonyGW
This message was authored by: tunneltiger
I had the same problem last year, I emailed viewer relations and a few hours later,  UHD was available again on my box.
Avatar for TonyGW
Thank you everyone for the suggestions.  Normal service has been resumed!  I think it was the viewing card refresh that did the job.  Very strange that it would just stop working seeing as my subscription had not changed and neither had my card.
