This discussion topic has been answered Discussion topic: UHD SET UP
Message posted on 10 Dec 2024 08:26 AM
I've just connected my sky Q box to a new tv but there is no 2160 UHD option to choose 1080 is as far as my options go. I did not have a UHD TV BEFORE.
Message posted on 10 Dec 2024 09:29 AM
As per @PandJ2020
Please see
If it is 32Cxxx then you have an older 1TB non-UHD Box
If it is 32B0xxx then you have a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then you have a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then you have a (V3) UHD HDR 1TB or 2TB Box
https://www.sky.com/help/articles/check-which-sky-q-box
Message posted on 10 Dec 2024 09:12 AM
Re: UHD SET UP
Do you have a UHD Q box?
As per @PandJ2020
Please see
Message posted on 10 Dec 2024 09:48 AM
Re: UHD SET UP
Hi @cokey12 Note, you also need a UHD subscription. Tell Sky that you need a UHD box when you order the UHD subscription.
