Discussion topic: UHD Flickering apps sky Q
Message posted on 25 Dec 2024 04:46 PM
I've been experiencing a flickering issue when using apps on my Sky Q box when the sky Q resolution is set to UHD. The flickering occurs across all apps, but when I switch the resolution to HD, everything works fine. This issue has only started recently, as UHD playback used to work without problems. And it should work when set to UHD problem is only with the apps on sky Q iv tried rebooting the sky box and updating and app refresh but not worked any one know how to fix it what else I could try thank you
Message posted on 27 Dec 2024 09:42 AM
Re: UHD Flickering apps sky Q
