7
This discussion topic has been answered Discussion topic: Sky box won’t supply signal to TV
This message was authored by: Elf490
Sky works fine following a reboot of the Sky box but overnight loses connection and requires a reboot again next day. System has been doing this for 6 months and getting progressively worse.
Re: Sky box won’t supply signal to TV
@Elf490
If you end up doing a 'doorstep box swap' whereby DPD deliver a new box and take your faulty box away, remember to remove the viewing card from the old box before it disappears into the van.
When yousay loses connection  @Elf490
Exactly what happens?
Avatar for Elf490
TV indicates that there is no signal from the HDMI input, I power down the sky q box for 10 seconds and then power back up, sky box goes through reboot process and then signal is restored and it works fine. Following day process is repeated.
Hi @Elf490
Avatar for Elf490
Hi @oldfella ,
Thanks for the information I will try this today and let you know how I get on!
Kind regards
ANdrew
Avatar for Elf490
Hi @oldfella ,
Sorry it took so long to reply, the fix/reboot process is not quick. I have ordered a new sky box as I am unable to get my current one to work as expected.
Thank you for your input and patience!
cheers
Andrew
@Elf490
Avatar for Elf490
Hi there, saga continues! Sky q box now connected to internet with all relevant IP addresses correct etc. however error message displays 'it looks like you don't have internet connection right now' even though the new sky box I received required an internet connection to pair the viewing card. Any ideas please?
