Discussion topic: Tv
This message was authored by: Sarahbarbagallo
Tv
I need a new remote. Recordings not coming up
Re: Tv
Could you expand on that? Not sure what yoy mean by "not coming up" or why the remote would affect something specific like that?
Re: Tv
Hi @Sarahbarbagallo
If you mean your Q box is not coming on
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
