Discussion topic: Tv switches off
This message was authored by: Seanritchie
Tv switches off
Just got Sky Q installed last week. Tv goes on for a few minutes then switches itself off. Then it goes on again for a few minutes & continues this cycle.
Re: Tv switches off
Hi @Seanritchie
