Discussion topic: Tv signal interference
This message was authored by: Ben60
My tv signal imhas interference and I have tried to ring Sky but it is near on impossible to speak to anyone
Re: Tv signal interference
@Ben60
Any error message displayed?
”No signal” tends to be a message from your TV (in which case check the cables going to the TV).
A “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye and could only affect one or two channels). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
