Discussion topic: Tv saying no signal. Sky Q box on red and flashing blue. Have tried to reboot. No luck
This message was authored by: Rosie521
Also tried to trigger software update by holding down standby button while switching back on but still the same. Sky box making a soft whirring sound
Re: Tv saying no signal. Sky Q box on red and flashing blue. Have tried to reboot. No luck
Hi @Rosie521
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Avatar for Rosie521
Yes, im receiving a new sky box tomorrow, so very useful info and tips; thank you.
