Discussion topic: Tv problems
This message was authored by Kaleigh This message was authored by: Kaleigh
Tv problems
Anyone else having issues with the picture going off and screen going black then coming back on? No error messages . Also when picture is it, it keeps sort of jumping. Same happens on recordings
Re: Tv problems
Hi @Kaleigh
First try rebooting your Q box
If you still have the issue check the the HDMI cable is correctly located in the Q box and TV.
Also try another HDMI cable if you have one.
Kaleigh
Re: Tv problems
I think it's the tv. Tried the bedroom tv and it's working fine. I've tried rebooting the box
Re: Tv problems
Hi @Kaleigh
Have you tried using a different HDMI input on the TV with the issue?
Kaleigh
Re: Tv problems
Haven't got a different lead 🙈
Re: Tv problems
Hi @Kaleigh
But have you tried the same lead but using a different HDMI input on the problem TV?
What did you try on the bedroom TV when you say this is fine?
