Discussion topic: Tv packages
This message was authored by: Pinky-1987
Tv packages
I have sky sports and sky HD which I'm now paying for but I no longer want them but don't know how I can get them taken off
Re: Tv packages
@Pinky-1987
To remove a part of your TV package you need to contact Sky giving the standard 31 days notice. If you have 'in contract' discounts you may not be able to remove them. Also make sure cancellation of a certain add-on doesn’t cancel another part of a discount.
You may be able to remove it via this link which includes a message option (usually available between 9am & 7.30pm) or by calling in using the number that should appear.
https://www.sky.com/help/articles/change-your-package-2-t2#downgrade
