Discussion topic: Tv not working
This message was authored by: Clarice4444
Tv not working
weak signal TV not working
Re: Tv not working
@Clarice4444  Weak TV sisgnal; normally is a TV issue and not something Sky supports with.
Or do you mean there is a signal issue with your Sky Q box?  What is the exact onscreen message you get.
Avatar for Clarice4444
Re: Tv not working
Yes the TV keeps saying waiting for connection from wi-fi device but I can't seem to figure it out
Re: Tv not working
Keeps saying the tv is waiting for connection for Wi-Fi-device but I can't seem to hook it up completely forgot on how
Re: Tv not working
The TV should not use wifi for anything Sky related
Is it on the right HDMI input?
