Discussion topic: Tv not working
This message was authored by: Gra9
Tv not working
Hi my sky tv hasn't worked since Friday?
Re: Tv not working
Assume you have tried rebooting your Q box @Gra9
Failing this exactly what happens after the reboot?
Re: Tv not working
@Gra9
We need a lot more information to provide advice. Any error messages? What have you tried?
Avatar for Gra9
Level 0 icon
Re: Tv not working
Once the reboot is done all it says is no satellite signal?
Re: Tv not working
@Gra9
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Avatar for Gra9
Level 0 icon
Re: Tv not working
Obviously I've done all of the above it's been five days now?
Avatar for Gra9
Level 0 icon
Re: Tv not working
My internet has been fine?
Re: Tv not working
Hi @Gra9
If you have been through the link @Daniel0210 posted
I assume you have booked an Engineer visit from Sky
Avatar for Gra9
Level 0 icon
Re: Tv not working
No not yet
Re: Tv not working
@Gra9 wrote:
No not yet
If it's already been 5 days @Gra9
Why not???
