This discussion topic has been answered Discussion topic: Tv not playing
Message posted on 19 Nov 2025 09:50 PM
Internet on. Good signal. Can get sky homepage but nothing will come on when selected....no live TV recordings or apps
Whats the problem and how is it fixed?
Message posted on 19 Nov 2025 09:54 PM
Hi @ColetteMcC
First try rebooting your Q box?
If the remote did not turn the q box on,
Hi @ColetteMcC
Message posted on 19 Nov 2025 10:11 PM
Re: Tv not playing
Thanks a million. All sorted
Message posted on 19 Nov 2025 10:12 PM
Re: Tv not playing
Sorted thanks
Message posted on 24 Nov 2025 07:29 AM
Re: Tv not playing
Blue screen each time I try to use my tv including apps this morning. I have tried to reboot but the screen is still blue.
Message posted on 24 Nov 2025 07:39 AM
Re: Tv not playing
Is this definitely on Sky Q, as there are Sky Glass issues this morning?
