Discussion topic: Tv keeps buffing
Message posted on 01 Jun 2023 05:52 PM
Tv keeps buffing
Tv keeps buffings
Message posted on 01 Jun 2023 05:58 PM
Re: Tv keeps buffing and unable to watch any programs
Unable to watch Tv
constantly buffering
Message posted on 01 Jun 2023 06:04 PM
@Angie+321 wrote:
Tv keeps buffings
Hi @Angie+321
First thing to try is a box reboot.
If the issue continues try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 01 Jun 2023 06:18 PM
@Angie+321 wrote:Unable to watch Tv
What are you trying to watch? Live broadcast, recording, catch up?
Message posted on 01 Jun 2023 07:12 PM
It happens on live and catch up
Message posted on 01 Jun 2023 07:56 PM
@Angie+321 wrote:It happens on live and catch up
Definitely sounds like a box issue rather than reception (live is via satellite, catch-up is via internet). Have you done as suggested in @oldfella 's post?
Message posted on 01 Jun 2023 08:23 PM
@Angie+321 is this your main box or a mini box ?
Message posted on 01 Jun 2023 08:40 PM
All we have 1 main and 3 minis all have the same issue
Message posted on 02 Jun 2023 09:26 AM
@Angie+321 have you done as @oldfella suggested???
Message posted on 02 Jun 2023 09:27 AM
@Angie+321 wrote:All we have 1 main and 3 minis all have the same issue
If the problem is with the main Sky Q (which it sounds like it is) then your minis will also, as they get their feed from the main box
