6
This discussion topic has been answered Discussion topic: Tv guide showing programme unavailable
This message was authored by: Mel79
Please can somewhere as we cannot not watch sky q mini in the bedroom as showing programme unavailable
Re: Tv guide showing programme unavailable
Hi @Mel79
Assume you are not trying to watch a UHD program??
If not
Reboot the mini as above.
Hi @Mel79
If not
Avatar for Mel79
Hello which one is the reboot button the the control please
There is no reboot button @Mel79
Just follow the instructions in my post.
These start with switching the Q box into standby with the remote control
Avatar for Mel79
Should the IP address be the same on both tvs?
Avatar for Mel79
I have done all the resets and the main sky q box is saying sky q mini not activated and has a x.
When I try to get a tick it will not change any ideas?
This message was authored by: Bw19
I done the above and it worked fine but next day it happened again and the following , trying to get help by ringing sky is very frustrating
