Discussion topic: Tv guide not complete
This message was authored by: Rebecca60
Hi my mini box tv guide is incomplete and wont let me record some of my programmes help please
Re: Tv guide not complete
@Rebecca60
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
Avatar for Rebecca60
Do you think that will help with the programmes not recording and Thankyou
If you still have the issue @Rebecca60
Once the main Q box is back up and running after the reset try rebooting the mini box again.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini (Amber led)
