Discussion topic: Mini box freezing
Message posted on 30 Apr 2024 07:38 PM
Mini box freezing
Message posted on 30 Apr 2024 08:24 PM
Re: Mini box freezing
@MANDY312 wrote:
How to stop mini box freezing. I have done all the trouble shooting
Hi @MANDY312
Reboot the mini as above.
