Discussion topic: Tv goes black, can hear programme.
Message posted on 22 Aug 2025 06:38 PM
Sky a goes black after about 2 hours of viewing, can hear the programme but can't change any settings as I can't see anything. Have done the usual turn off things. Works again next day....until 2 hours later. And why can't you directly chat to sky!
Message posted on 22 Aug 2025 06:48 PM
Re: Tv goes black, can hear programme.
Hi @FionaWoody Are you sure that you TV does not have an auto power saver by blanking the screen if no interaction occurs (like volume change) set to two hours. I have mine set to 24 hours.
Message posted on 22 Aug 2025 07:14 PM
No, if we change off sky q it's ok...then go back to sky q and it's still blank....
Message posted on 22 Aug 2025 07:43 PM
Hi @FionaWoody Try changing the ECO settings to Active or None. Standby Settings
Message posted on 22 Aug 2025 09:36 PM
Ok, have done, thanks. Will see what happens but we've had this sky Q for years and this has never happened 🤷🏻♀️
Message posted on 22 Aug 2025 09:55 PM - last edited: 22 Aug 2025 09:56 PM
It shouldn't be eco mode as that takes 4 hours to activate (except after 11pm) and it turns the box into standby so you wouldn't be able to still hear the programme.
Message posted on 23 Aug 2025 07:45 AM
Agreed. This is very weird
Message posted on 23 Aug 2025 09:44 AM
Spoke to sky and they are sending a new box....they suggested an engineer but a new box sounds way easier!
Message posted on 23 Aug 2025 10:26 AM
@FionaWoody wrote:Spoke to sky and they are sending a new box....they suggested an engineer but a new box sounds way easier!
Hi @FionaWoody We can't say it offten enough, please remember to keep your viewing card, and swap the power lead with the box.
