Discussion topic: Tv box
Message posted on 20 Jun 2023 06:09 PM
Tv box
I have a little second box for my main tv as the sky receiver is in my bedroom and cannot be moved and it will not turn on now. Have a red light but no orange or green.
Message posted on 20 Jun 2023 06:24 PM - last edited: 20 Jun 2023 06:26 PM
Re: Tv box
Hi @Lorna13
First try rebooting the mini
Have you tried pressing the Standby button (Amber led) on the front of the right of the mini box.
If this turns the mini on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
