Discussion topic: Tv and phone
Message posted on 21 Mar 2023 08:34 PM
Tv and phone
Since having my new internet box fitted the other side of the room to my tv and phone my sky tv isn't working and I can't ring in or out on my phone
Message posted on 21 Mar 2023 08:38 PM
Re: Tv and phone
You mean a router/Hub? Do you have Sky Broadband?
Message posted on 21 Mar 2023 08:47 PM
Re: Tv and phone
My router works my sky tv and phone line isn't working
Message posted on 21 Mar 2023 08:51 PM
Re: Tv and phone
@marie+gillard Is there a voice light on the new hub? Is this lit up?
Message posted on 21 Mar 2023 08:55 PM - last edited: 21 Mar 2023 08:57 PM
Re: Tv and phone
@marie+gillardWhat exactly did you have done, if your phone has been changed to "VOIP" then the phone needs to plug into the back of your hub/router into the socket marked phone. There will be no dialling tone but it should work, if that has been done you will have to dial the full national code including the 0, likewise anyone phoning you will need to dial the whole code.
Message posted on 21 Mar 2023 09:07 PM
Re: Tv and phone
Hi I had a new sky I think it's called q box fitted they have fitted this the other side of my room so no wires will fit to tv or telephone like they used to they guy who fitted it said it is fine we're it is but nothing has worked since
Message posted on 21 Mar 2023 09:59 PM
Re: Tv and phone
@marie+gillard Here is information on how to set up Q devices
https://www.sky.com/help/diagnostics/setting-up-sky-q/what-sky-equipment-do-you-have
Message posted on 21 Mar 2023 10:05 PM
Re: Tv and phone
Hi I don't have a new box only internet box therefore shall I plug in my old internet box and keep using this thanks for your help
Message posted on 21 Mar 2023 10:42 PM
Re: Tv and phone
Can you get a photo of what this new box is? Or does it have a label naming it? Sounds like you were given a new router for some reason.
