Discussion topic: Turn off pin protected programms
This message was authored by: afsgdterfw
Turn off PIN protected shows
Re: Turn off pin protected programms
When SKY Atlantic & other channels show certain material before the relevant 'watershed' it will always be present & you cannot turn it off
https://helpforum.sky.com/t5/Sky-TV/Is-there-any-way-I-can-turn-this-damn-parental-control-off/ba-p/...
Do check that all the relevant options in Parental Controls are appropriately set but as I say you may need it for some
Our advice is to set the PIN to something like 1111 to help enter it when needed
Hi @afsgdterfw   Your question is very vague as you don't mention the type of programme or you don't know how to set your pin settings. However in general https://helpforum.sky.com/t5/Sky-TV/Is-there-any-way-I-can-turn-this-damn-parental-control-off/ba-p/...
Avatar for afsgdterfw
Parental controls are all set to off. When watching a crime channel it requests I enter my pin at the end of every program.
Some channels including Sky Crime can show programmes that are only suitable for adults before 9pm, but under Ofcom rules these must be PIN protected, even if the user has turned off PIN protection.
hi @afsgdterfw
Regardless of what settings you have on your Q box Ofcom dictates the following:-
Television broadcasters must observe the watershed.
Therefore regardless of your settings pin entry will be required in some instances.
Hi @afsgdterfw   If you are saying that you are being prompted for your pin in the wrong place, then I would contact viewer relations [email protected]
This message was authored by: Spanner11
Its so annoying having to put in a pin in to watch a program, when NO KIDS are in the house, you should have control over it, whats the point of parental controls if you can not turn it off, if they are all off this should be too, or make so its on by default and can be turn off using it own setting.
Its a silly idea, and especially if someone not use to put in a pin and then put it in wrong 3 times(older people), the pin is only for the Sky Q Box, its not used online or anywhere else.
If there's no kids around then set the PIN to something simple, e.g. 1111
UK broadcasting regulation, based on law made in Parliament, says otherwise.
Any 'Parental Controls' offered by a regulated platform are in addition to Mandatory Daytime Protection, as defined in the Broadcasting Code.  The Code specifically states that a platform must not permit customers to remove MDP.
Yes, because in this case the relevant Act of Parliament is over two decades old and so long pre-dates internet speeds fast enough for streaming: it applies to broadcast platforms, content and service.
This message was authored by: Liam+Nolan
It's even more annoying when you're in Ireland where ofcom rules don't apply.
@Liam+Nolan
Strictly speaking that's correct, but I'd think Sky would argue the PIN is effectively fulfilling the requirements set by BAI.
The Code of Programme Standards of the Broadcasting Authority of Ireland (BAI) requires television and radio broadcasters to use at least one of three methods to advise viewers of content, namely: an explicit watershed for adult-oriented programmes; prior warnings before potentially offensive programming; and/or a descriptive classification system.
https://en.m.wikipedia.org/wiki/Watershed_(broadcasting)
This message was authored by: KT140486
It's not helpful when you don't have children, I have ADHD and trying to fall asleep watching True Blood downloaded to the Q box but instead of just auto playing each episode it demands the silly pin every single time. That is ridiculously inconvenient in this day and age when the real issue is giving kids from a very young age access to YouTube and the wider internet more so than it is them accidentally watching something pre watershed on Sky Atlantic
@KT140486 alas the law is what it is currently (as explained above)
This message was authored by: Sleepybint
This exactly
never used to pop up on crime channel now it does
everything I'd set to off
