Discussion topic: Trying to connect Sky Mini Box in remote room
Message posted on 26 Nov 2024 07:15 PM
I've just had a new garden room built. I want to connect a Sky Mini Box in this room. I'm on Sky Broadband, and have an access point outside, so WiFi signal is very good. The room is about 12 metres away from the building with the Sky Q main box.
Whats the best way using WiFi for me to connect my mini box?
Message posted on 26 Nov 2024 07:36 PM
Re: Trying to connect Sky Mini Box in remote room
Hi @cheese26
Exactly what is your Access point?
Message posted on 26 Nov 2024 07:38 PM
It directly linked to the main router via Ethernet. Provides excellent coverage to the new room.
Message posted on 26 Nov 2024 07:39 PM
Message posted on 26 Nov 2024 07:54 PM
Not sure of the spec but it's a Ubiquiti Wall. Network company installed.
Message posted on 26 Nov 2024 07:58 PM
Message posted on 26 Nov 2024 08:03 PM
As your router is SKY then you should be able to connect the mini to your ethernet cable instead of your current Access point & the mini should then also act as an access point to your network
Message posted on 26 Nov 2024 08:19 PM
Will my Sky Q be close enough; it's about 12 metres away in another room?
Message posted on 26 Nov 2024 08:20 PM
So I don't have an Ethernet connection in the room, just WiFi via the access point.
Message posted on 26 Nov 2024 08:23 PM
Sorry I misunderstood where your Access point is - I thought it was in the room
Message posted on 27 Nov 2024 08:21 AM - last edited: 27 Nov 2024 08:22 AM
Add a ubiquiti node in the garden room. It should be able to mesh with the existing one, I think, and connect the mini to that over ethernet. (I don't know this device, using general principles here)
Message posted on 27 Nov 2024 10:33 AM
As far as I am aware @Chodley
this will only work if all Q boxes are connected to other mesh nodes
Message posted on 27 Nov 2024 10:49 AM
@oldfella wrote:
@Chodley wrote:Add a ubiquiti node in the garden room. It should be able to mesh with the existing one, I think, and connect the mini to that over ethernet. (I don't know this device, using general principles here)
Interesting. In a normal networking world, that shouldn't be necessary but Q's networking has never been labouring under the adjective "normal".
