Discussion topic: Trying to boost the SkyQ mesh
Message posted on 28 Sep 2023 11:10 AM
Hi all,
I'll give a quick overview of my setup :
TPlink VR2800 modem/wifi router connected to sky broadband
2 * TPlink RE200 range extenders connected with the same wifi SSID as the main router, so devices can pick best route to internet.
SKY Q main box connected via ethernet to one of TP link extenders and set to ethernet broadband connection. 2.4G and 5G wifi still enabled .
SKYQ mini connected via ethernet to one of TP link extenders 2.4G and 5G wifi enabled.
Sky Q mini connected via wifi
SkyQ mini connected via wifi.
So..the original issue was that having moved the main Q box into a cupboard below the TV , the broadband connection for the main box and the Q connection to the minis was intermittent. Now the main box is connected via the TP link extender, the broadband link is stable. The issue is that the minis ( even the one connected via ethernet ) still have the occasional bad connection ....picture stuttering etc. I run Netflix speed test on the mini ( ethernet one ) and its getting 30Mb...so I am wondering if the Q mesh link from the main box is the culprit ...it seems as though only sat feed tv is degraded. . I believe q mesh only uses its own 5Ghz wifi link, so the ethernet connection wont help.
I have an old Sky Q booster ( white one ) , so am wondering if this will boost the Q mesh or is it just used to boost broadband. ?
Anyone got advice how to sort this. I dont want to take the main box out of the cupboard ( its a media wall and sits hidden below the telly using the bluetooth connection from the new sky remote )
Message posted on 28 Sep 2023 11:49 AM
Re: Trying to boost the SkyQ mesh
Hi @GuyTrem
Not aware that you can clone Sky Q WiFi and so I suspect the minis are still trying to connect to the main Q box WiFi mesh.
Only a Sky Q booster will work with Q and not the normal Sky one.
Best if you can get all the minis connected by the same method as the main Q box.
ie Ethernet to TP link device.
Message posted on 10 Oct 2023 06:58 AM
Ok , so a slightly different question. The only weak link seems to be the main box to the router. I will try connecting via ethernet over a powerline adapter. I will need to leave the other mini boxes on the 5GH SKy mesh .
Question is , has anyone ever got this to be stable ...ie the main box connected to internet via ethernet and then the minis use the sky mesh to connect to it . ? ( I have a sky Q booster helping the mesh ...I can see it logged into the mesh SSID on the 5GHz band )
Message posted on 10 Oct 2023 10:19 AM
Hi
What mesh are you talking about at the end there? I don't think it's possble to see what devices are connected to the Q mesh without the kit the sky installers use, and your extenders are not a mesh.
minis can use an ethernet network to get to the Q, doesn't have to be the internal mesh.
Could maybe try the Q booster on ethernet out of the back of the Q (via a switch if you need to also use that socket for the powerline) - might allow the minis to find it and therefore the Q. This networking is so unusual it's worth trying anything.
Message posted on 10 Oct 2023 12:47 PM
Ok , to explain a bit further.
I think I am correct when I say that the main SkyQ box will connect to a 3rd party modem/router on the 2.4GHz band or via ethernet. It then creates its own sky mesh on the 5GHz band ( with a different SSID to the router ) which the mini boxes connect to . If you install a SkyQ booster2 ( which I have ) , it seems to connect to the 3rd party router on the 2.4Ghz band , but also connects to the sky mesh on the 5GHz band. I can see this because if I log in to the booster on its web ui , I can see the two different SSIDs being used. ( one to the router and the other to the skymesh. ) . So I am assuming that the booster is boosting the two SSIDs around the house.
My query was what happens if I hard wire the main Q box to the router, but leave the mini's using the skymesh ....is this a stable setup ?
I ask because I heard in the past that its an all or nothing scenario....ie all boxes on wifi ( including the main q box ) or all boxes hard wired . Mix and matching doesnt work well ?
Any thoughts ?
Message posted on 10 Oct 2023 05:02 PM
Ah ok.
I think that will work. The booster isn't acting as a hotspot for the 2.4GHz network afaik, just the Q's mesh.
What might be glitchy is the Q might flip to using wifi now and again for the internet connection, and if that's flakey, as it usually is, it will cause problems.
Message posted on 10 Oct 2023 05:17 PM
Hi @GuyTrem
Not sure what a Sky Booster 2 is.
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with.
Only the Q WiFi booster will connect to the Main Q box by WiFi. Ordinary Sky Boosters will not.
