Discussion topic: Trouble with with main and mini box
Message posted on 10 Nov 2024 06:24 PM
Have trouble with main and mini box tv guide works on main box but not any recordings. Mini box just says no satellite signal and cannot even get tv guide
Message posted on 10 Nov 2024 06:25 PM
Re: Trouble with with main and mini box
Reboot the mini as above.
