Discussion topic: Trees blocking satellite signal
Message posted on 11 Jul 2026 04:23 PM
Will sky move the dish if trees have started blocking the signal. TNT is terrible and normal channels have started to glitch
Message posted on 11 Jul 2026 04:27 PM
Re: Trees blocking satellite signal
Providing there's a suitable alternative spot for it the short answer is…
Sky Q - Yes and will charge about £65
Sky+ - No. Sky no longer support Sky+ set ups
Which do you have?
Message posted on 11 Jul 2026 06:40 PM
Sky Q and could use gable end
Message posted on 11 Jul 2026 06:54 PM - last edited: 11 Jul 2026 06:56 PM
So you need to contact Sky to arrange that. It will obviously be down to the engineer to establish that any alternative location is suitable
Message posted on 11 Jul 2026 06:57 PM
@Cghhbffhj wrote:Sky Q and could use gable end
Hi @Cghhbffhj Depends on height. Sky standard installers would only consider 1st floor. It is worth mentioning while booking if a special heights team is required.
